NI- USRP Configuration Utility with USRP X410 doesn't show the FPGA Image
i am new to work with Ni-USRP and wanted to used NI-USRP Configuration Utility in the Step 7 of USRP-X410 LabVIEW Configuration USRP-X410 Getting Started. My problem was to find a FPGA Image for N2xx/NI-29xx/X410 Image Updater tab of the utility, because i don't see any FPGA Image file for USRP X410  on National Instruments/NI-USRP/images. Maybe, i am looking for the wrong path? I was thinking that the updated embedded system file will be automatically loaded on  NI-USRP Configuration Utility, but it is not the case although the previous steps were conducted successfully. Do you have any suggestions how to solve this issue?
Olivia
Message 1 of 1
(810 Views)
