NI-VISA Runtime 4.3 Additional Installer problem
I am using Project Explorer and I'm trying to include NI-VISA Runtime 4.3, but during the build I get a message that says:
Locate the "Activate" distribution. LabVIEW needs to copy a component installed or updated by the distribution to continue building the installer.
I don't know what the "Activate" distribution is or where to find it! Please help.
See attachments.
Message Edited by Sidd on 10-09-2008 02:02 PM
(3,687 Views)
If you are using the Volume License Manger this thread may help you.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,656 Views)
Accepted by topic author Sidd
Thanks for the suggestion but I solved the problem a different way.  I downloaded NI-VISA Run-time 4.3 from http://joule.ni.com/nidu/cds/view/p/id/989/lang/en then extracted it to a folder.  I pointed Project Explorer to this folder and it found it properly.
I was then able to build the project successfully.
Sidd
(3,647 Views)
