NI VISA error -1073807331 occurred at property node (arg 2) in visa configure serial port.
I have a software which runs fine on one PC but on another PC we are using we are getting an error in the VISA VIs. error -1073807331 occurred at property node (arg 2) in visa configure serial port and -1073807343 error at old visa open. I am not able to find the possible mistake in the code. I doubt its related to the inputs we are giving the VI, also I have observed that the NI max in this PC is having a error " The Max Database existed abnormally" to solve this problem I used NI white paper "MAXTerminatedServiceError When Using NI MAX" but its not helping.
Let me know how should I approach this issue and solve it? Also does the NI max error has any influence on the problem we are facing in VISA?
I am also attaching the photo of the error.
(376 Views)
Hi Aliza24102002
This error happens when the computer cannot communicate correctly with the device it is sending commands to.
Please follow Error -1073807343 When Reading/Writing VISA to Serial Port in LabVIEW or LabWindows™/CVI article for troubleshooting steps, it may help in this case.
(303 Views)
