NI-VISA installation fails on Scientific Linux 6.0
Hi!
I am trying to install Labview 2012 on Scientific Linux 6.0 (regarding to the NI website this distro is supported).
The LabView installation works fine, but the subsequent NI-VISA installation terminates with the following error msg:
# ./INSTALL
  NI-VISA for Linux
     version 5.2.0f0 for Linux
National Instruments products support the following Linux distributions:
   openSUSE
   Red Hat Enterprise Linux Desktop + Workstation
Refer to README.txt for the latest information at the time of release.
Refer to www.ni.com/linux for the most recent information about Linux
support at National Instruments.
Continue? [Yn]
Checking required install tools...
Checking installer tool versions...
rpm        4.8.0 can be used with a default installation path
tar        1.23
Checking dependencies...
glibc      2.12
2.12
Unpacking install files to /tmp/nivisa-5.2.0f0.install...
******************************** ERROR ****************************************
* The version of gcc in the path does not match the version of gcc used to    *
* compile the currently running kernel.  This can cause unpredictable         *
* behavior in kernel drivers and should be fixed.                             *
* gcc version: gcc-Version 4.4.6 20120305 (Red Hat 4.4.6-4) (GCC)                                                           *
* kernel compiled with: 4.4.6                                                 *
Installer is aborted.
Obviously the installer finds the kernel source and gcc 4.4.6. Is there anything I can do to install NI-VISA on the system? If not, could you suggest me a linux distro which works with LV2012? I am tired trying several ones.
Thanks for you help!
(2,591 Views)
have a look to this link:
http://digital.ni.com/public.nsf/allkb/463B062FB2416B2F86257942007233B4?OpenDocument
Maybe this could help you
Regards
Philipp
(2,546 Views)
