NI VISA, unable to find VISA configure serial port
Hi all,
seems I made a mistake somehow and know I am unable to use VISA configure serial port.
When selecting from the palet, the icon appears translucent and I cannot connect it.
When trying to access the example, it can't be found anywhere.
I already try to repair my install. Doesn't fix the problem.
I try to setup NI VISA, doesn't fix the issue.
It also seems I lost the dependancies somehow.
If anyone got an idea.
(3,170 Views)
Open MAX.  Expand the Software Tab.  Take a screenshot showing the installed software and post it here.
Bob Schor
(3,160 Views)
What version of LabVIEW do you have installed?  What version of VISA do you have installed?
(3,152 Views)
(3,147 Views)
I would try to install the NI VISA again.  Do not do a repair.  Just run the install as normal.  My thought is that the "LabVIEW Support" was not installed for some reason.  Just running the installer again should pick that up.
(3,144 Views)
Already tried,
the setup doesn't want to install again.
And LV support was set up
Just to make sure, you were talking about NI VISA 18.0 ?
I will try the remove and re-install option
EDIT : just try to reinstall, nothing changes
(3,136 Views)
Solved : Uninstall and resinstall labview completelly.
Not the best way but work out
(3,084 Views)
