NI Variable Engine not starting...
Working on a data acquisition project using a cRio 9041, and I'm trying to set up some shared variables. However the NI Variable Engine service isn't starting.  My problem seems to be similar to
https://forums.ni.com/t5/LabVIEW/Can-t-get-Shared-Varaible-Engine-to-Start/td-p/2614319?profile.lang...
but the solution there doesn't work for me.  It says that the PSP Service Locator service has to be running, but when I try to start it I get the error "Windows could not start the NI PSP Service Locator service on Local Computer.  Error 1069: The service did not start due to a logon failure."
Logon failure???
NI Configuration Manager is running
When I try to start the NI Variable Engine, I get "Windows could not start the NI Variable Engine service on Local Computer.  Error 1068: The dependency service or group failed to start."
Anyone have an idea why these aren't starting?  Or how I could get them to start?
J
(4,945 Views)
I got a same problem with the newly installed LabVIEW 2021 (64bit). My problem is fixed with following procedure.
Open Windows Services, right click "NI PSP Service Locator" service -> Properties -> "Log On" tab -> select "Local System account".
Apply and then start this service.
After that, start "NI Variable Engine" service.
(4,541 Views)
