NI Variable Engine (tagsrv.exe) Runtime Error Dialog Upon Restart -- Resolved
After installing LabVIEW 2009, I started getting an error dialog when I restarted, and shared variables stopped working.  So, I figured I'd post what I did to resolve it.
For forums searchability, here's the text:
Dialog Window Title:
Microsoft Visual C++ Runtime Library
Dialog Window Text:
Runtime Error!
Program: ...gram Files\National Instruments\Shared\Tagger\tagsrv.exe
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information
Here's the dialog:
I also noticed that the NIVE (National Instruments Variable Engine) service timed out when I manually tried to stop it.
So, I:
    * Closed out of everything, opened Distributed System Manager 2009, and removed all processes (except for "System", of course)
    * Restarted the PC
Visual C++ Runtime error is gone! 😄
Message Edited by LabBEAN on 11-11-2009 10:02 AM
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
Message 1 of 16
(9,373 Views)
Hello LabBEAN,
Thank you for taking the time to submit this valuable feedback.  This was reported to R&D (#196095) for further investigation.  Thank you also for providing the detailed workaround.
Message 2 of 16
(9,311 Views)
I am getting the exact same dialog every time I restart my computer. When I go to the Distributed System Manager there are no processes to remove.
I believe I started getting this error after I started working with projects that have a cRIO target.
It is getting annoying to get the same dialog box every time I reboot the computer.
Any idea how to get rid of this window?
Fab
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
Message 3 of 16
(8,958 Views)
Maybe install Distributed System Manager 2009 SP1?
Message 4 of 16
(8,948 Views)
This seems to have resolved the issue. Thanks!
Message 5 of 16
(8,927 Views)
Nevermind. That did not solved it. I am still getting the same error. It only went away from a couple of reboots, now it is back.
Message 6 of 16
(8,758 Views)
Corruptions can happen.  At one point on one of many, many shared variable Service Requests I've had with NI, an R&D guy connected to my PC and used some tool to "clean out" my NIVE (NI Variable Engine).  So, you either have something REALLY corrupted and need to uninstall/reinstall LabVIEW...
...or you are causing this corruption repeatedly by something you're doing.  In this latter case, my instructions above should clear it up.  Then, you would need to explore why you're code is breaking the NIVE.
Message 7 of 16
(8,754 Views)
Thanks LabBEAN.
I did remove all the processes from the Distributed System Manager, then restarted the computer, but the message is still there. So, I guess I will have to try uninstall/reinstall LabVIEW... not fun 😞
Thanks again,
Fabiola
Message 8 of 16
(8,712 Views)
Sorry to hear that.  I've been there a few times myself.  While you're going through that process, consider uninstalling EVERYTHING NI through Control Panel » Add Remove Programs.  Running msiBlast (attached below) can clean out anything you missed.
As a last resort, you could call NI support (if you have support) and at least allow them to probe around.  At a minimum, they can document this internally so maybe it's fixed at some point.  If you go that route, request a CAR number and post it back here if they give you one.
Message Edited by LabBEAN on 04-23-2010 05:39 PM
Message 9 of 16
(8,708 Views)
Actually, I just looked above and Burt provided this number:  196095
You could reference that CAR if you call them.
Message 10 of 16
(8,705 Views)
