NI VeriStand - 'Set channel values by block data reference.vi'
I make an asyncronous custom device application on a VS proj and
I would like to change programmately the value of the channels output list inside RT driver.
I find the function 'Set channel values by block data reference.vi' but it sets the values of an inline custom device channels..
I wonder if exist the same function to asyncronous custom device or if there is the possibility to do that in other way?
thanks,
best regards,
Marco
(2,588 Views)
This is the LabVIEW forum you may want to try the VeriStand forum
http://forums.ni.com/t5/NI-VeriStand/bd-p/440
There are some here that of course are familiar with VeriStand but I'm guessing you'll get more help if you posted there instead.
(2,574 Views)
