NI Web Service Configuration from the installer
I am looking for a way to install a default configuration for the NI Web Server upon installation of an installer (msi) built with LabView.  Specifically I have an application that includes a webservice attached to the .exe.  When installing on a remote computer I would like the NI Web Service to initially be setup with a few default settings without requiring the operator installing the application to have to open the NI Web Server configuration tool. (HTTP/HTTPS Port, Remote Access Enabled.....)
Is there a way to install a default configuration to the NI Web Server? Or is there a way to configure the NI Web Server from either VIs or the command line?  (This way I could build it into the post installer activities.)
M
Message 1 of 1
(1,853 Views)
