NI Webserver app change port
window System:window 10 professional 64  Chinese Simplified Chinese and window 10 professional 64 Simplified Chinese
browser:Chrome and edge
labview:labview 2024Q3 32bit CH
issue description:
1、when i want to build a application  at first is ok  and when the application is installed,the error occurred,Error-67404,but when I user the webservice  it is OK.so this bug is Low Priority
2、I want to change the web app port then I open thebrowser and input http://localhost:8081/web-config/web-servers an error occurred (pic5) and I can not change the http port.
(365 Views)
Accepted by topic author liuai987
I have solved the problem the reason is I did not  install theNI web configure tool . so I install the tool  in the ni packgage manager. then the problem solved.
(317 Views)
