NI cDAQ-9184 Connection Issues
I am working on a network with multiple computers, but only one that had LabVIEW and NI MAX installed. I am making a program that can write to NI 9482 which is mounted on NI cDAQ-9184. On the computer with LabVIEW and NI MAX, I made sure to unreserve the network device and make sure that the program does the reservation itself, I am able to run a successful self-Test, and my program works as intended.
My issue lies with trying to install this program on other computers in the network. I created an executable, then an installer that I made sure had all of the required additional installers and the Hardware configuration file. But when I install and run my program I get Error -88705, that the device is not present in the system. So I checked NI MAX which was installed with my program installer, and I found that the device shows up and the status is "Connected - Running" although it says the device is not reachable. The self test also fails.
What can I do to be able to communicate with the devices from any computer on the network?
Thank you.
(1,430 Views)
More information would be helpful here.
I suggest starting with:
  • Listing versions of whatever you are using (DAQmx, LabVIEW, Windows, etc.)
  • Screenshot of the NI-MAX entry for the device on the working system
  • Screenshot of the NI-MAX entry for the device on one of the non-working systems
  • Attach the subVI from your code that makes the connection (back-saved to 2020 or so, if you're using anything newer)
(1,391 Views)
Here is some info about my working and non working systems. Please let me know if anything else would be helpful.
Thank you!
Working System:
  • LabVIEW version 20.0.1
  • NI MAX version 20.5.0f0
  • Windows 10
Non Working System:
  • NI MAX version 2024 Q2
  • Windows 10
(1,362 Views)
Are all computers and the cDAQ on the same subnet? I've had strange behavior before when something's set to DHCP and I can see it in MAX but it won't connect. Usually MAX gives a hint if that's the case though because it says Inconsistent IP settings, which I don't see in your screenshots.
(1,319 Views)
