NI cDAQ9184 getting disconnected automatically
Hi friends
 I used cDAQ9184 with NI9205 and NI9624 modules in our project, cDAQ getting disconnect automatically while running the machine, It is happen occasionally, How  can we solve this problem ?
 Thanks in Advance
(1,099 Views)
First you need to figure out why it is disconnecting.
Only after you figure that out can you figure out how to prevent it.
(1,055 Views)
Thanks for the reply
Actually this machine is nearly 5 years old , Now only this error happen,
also this will occur Occasionally(This is an 24 hours continuous running machine)
If any hardware related settings present???
(1,036 Views)
