NI cRIO 9049 reboots when running RT application as a startup rtexe
Hi all,
I am using cRIO 9049 for my application. I am facing cRIO reboot issue when i am running application as a startup app. Same software works perfectly fine when i run that through RT Launcher.
I checked CPU usage when running though LabVIEW development software, its ~45-50%, also there is enough memory on cRIO.
I am using LV2021
Any thoughts, why this could be happening?
Thanks and Regards,
Ashwini A Pandit
Thanks and Regards,
Ashwini A Pandit
Wired-in Software Pty Ltd
(1,239 Views)
Just to clarify, you need to reboot the RT target when you deploy and set a startup RTEXE from LabVIEW ADE for the startup setting to take place.
Are you saying that your cRIO keeps rebooting? How long it will run before rebooting? 10 mins?
https://tmesystems.net/
(1,211 Views)
Thank you ZYOng for response.
cRIO reboots once I deploy my .rtxe as it supposed to be. but after that within one-minute cRIO reboots and keep on rebooting.
Thanks and Regards,
Ashwini A Pandit
(1,173 Views)
It sounds like the cRIO crashed due to the memory leak. Try to log and monitor the memory usage. See Error -2147220623: Largest Memory Block Property Does Not Exist
(1,169 Views)
Thank you ZYOng.
I monitored memory while its running through development system, it's quite low. Also monitored memory when its running as a rtexe, I didn't see any surge in memory.
Article link given by you, recommended trying disabling 'Embedded UI option', when i disabled it, cRIO is not rebooting.
But for debugging purpose, i need to see what's happening in my VIs, is there any other way than disabling 'Embedded Ui' option?
Also, I still don't understand what's wrong with my cRIO.
Ashwini A Pandit
Thanks and Regards,
Ashwini A Pandit
(1,144 Views)
Try checking Error Log File for My Real-Time Controller Crashes
(1,140 Views)
Thanks, ZYOng.
I am getting error when I try to open error log using NI MAX, but I managed to fetch LV Error file from /var/local/natinst/log folder. Please see attached screenshot, it says 'address not mapped to object'. I found similar issue's post on forum: https://forums.ni.com/t5/LabVIEW/cRIO-9068-segmentation-fault/td-p/4063417 but it is unresolved.
Does anyone know about this Error?
After digging more log files, I found Kernel error file (Please find Attached). Can you please tell me, what could be the reason for reboot?
Thanks, and regards,
Ashwini A Pandit
Thanks and Regards,
Ashwini A Pandit
(1,125 Views)
