NI cRIO-9074, NI 9263 AND NI 9225
Hi everybody,
I am student of electrical, I have the thesis in this semester.
I have the labview 2012 and 3 NI kits ( NI cRIO-9074, NI 9263 AND NI 9225)
who can give me some exambles that is made by what I had.
or you can give me a project that I can do with it.
thanks all!
(3,023 Views)
Don;t call it 3 NI kits: because NI cRIO-9074 is a cRIO chassis with integrated controller and NI 9263 & NI 9225 are cRIO modules... So they make sense (or can be used) when clubbed together (modules should be inserted in the chassis).
@aloalo wrote:
I have the labview 2012.
Do you also have, FPGA and RT module (software pieces) installed in your computer? These will be required to write and deploy a LabVIEW code for cRIO.
Why don't you come up with an idea of yours, and people in this forum/community will help you implementing that idea. Why do you want a readymade solution, which you have not made it yourself...!!
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,015 Views)
thanks for your advise, but I just want to know some applications of these. because I dont know anything about cRIO-9074, NI 9263 and NI 9225, and I think the fastest way to access all of theme is learn from some exambles about these that I dont have!
About Labview, I have many tookit incluce FPGA, I want to use labview to simulate the  control system for asychronuos motor ( the law of control is V/f = constant and use PID control). I have some problems is that:
     1) I want to connect it to PIC chip, you can give some document or video about this.
     2) I want to programming the sinPWM to control asychronuos motor and I dont know can labview do it?
(3,004 Views)
