NI cRIO Remote Front panel
I am trying to acces the NI cRIO Remote front panel (to see the RT output)  from my PC that is on the same network as my Target (cRio) via internet explorer.
But when i write the ip address of the target in the URL box, instead of  openeing remote front panel it opens system setting dialogue window-configuration box. The attached file shows what i am getting instead of front panel.
Can anyone tell what should be the problem?
Thanks!
Farhan
(3,401 Views)
that page is the silverlight configuration page which is defaulted to port 80
if you enabled remote panels and deployed the settings  then the default port for remote panels is 8000
so type the ipaddress:8000   to get to it
you can turn off or change the port number for the silverlight page and change your remote panel port back to 80 so your user doesn't need to enter the :8000 at the end of the url
another tip is change your remote panel webpage to index.htm  so it automatically goes to the correct page by just typing in the ip address
- James
Using LV 2012 on Windows 7 64 bit
(3,366 Views)
