Kirkland4-
Thaison has asked my response as a second opinion. With this issue it is all in the wording. IMAQ hardware and software has not been fully tested on 64 bit computers; either in 32 or 64 bit OS. Therefore, we are hesitant to say whether it will work or not. At this time our official answer is that it is not supported. This does not mean that it will not work. It simply means that we have no official answer and at this time is unsupported. Personally, I think that as long as you are using a 32 bit OS it should work. Once again, that is not official merely my thoughts. I hope this helps.
John H.
http://www.ni.com/support
