NI embedded system control board
Hello, everyone. I am using sbRIO-9627 embedded control board to make flight control system, including main control program, RT program and FPGA program. I want to know if there are any more powerful boards than I use now. Thank you.
(2,418 Views)
Hello uestcer,
I think "more powerful boards" is very ambiguous. What do you need or expect to increase?
  • Faster performance/capacity? Maybe the CompactRIO line can be the solution and is commonly used for Hardware-In-The-Loop (HIL) testing.
  • Similar resources but smaller form factor? Perhaps a system-on-module RIO.
  • Larger FPGA? Possibly an R series card will have enough slices for you to program more complex algorithms
  • A complete platform? Bloomy has a ready-to-go Flight Control System Test Platform.
All the best,
(2,399 Views)
