NI modbus toolkit is unreliable?
I am controlling a Watlow F4 in LabVIEW using the modbus add-on toolkit.  When I started writing this application, I used some modbus vis that I found in the devzone, but wasn't too keen on using somebody else's unknown code.  I thought that using NI's kit would make things more robust.  Instead, I am now encountering timeouts and bad data reads.
I am running a diagnostic right now, reading a series of about 40 registers and comparing the resulting array to an array of known good data.  The NI toolkit fails to duplicate the good data within 5 runs.  The vis I got from the board have run for, let me check... 96 iterations so far without error.  What's the deal?  Anybody else have complaints about the modbus toolkit?
Has anybody used the Automated Solutions .NET tools (http://www.automatedsolutions.com/products/dotnet/ascomm/mb.master.serial.asp)?  Or any other 3rd-party tools?
Ed K.
(2,911 Views)
Accepted by topic author yafoteer
If your talking about
https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019
It's not officially supported, and there are a few bugs with it (just check the comments). The big one is that MB CRC-16.v returns a u8 instead of u16. Fixing that is easy and will likely fix your problem. You can try the other bug fixes if them seem like they're relevant. The official way to use modbus is through the dsc module.
https://www.ni.com/en-us/shop/product/labview-datalogging-and-supervisory-control-module.html
I'm using the first library, so I haven't tried anything else.
(2,904 Views)
Yes indeedy.  And I need to be much more careful about trusting anything that has "NI" in its name.  Thanks for the reply.
(2,888 Views)
