NI usb-485 vs LabVIEW 2013
Hi
Please, help me!!
I try use the NI USB - 485 with LabVIEW 2013, but not working, the NI MAX don`t identify the device, I have install the drive NI Serial 4.0. Somebody can say me, what happen? the hardware is not compatible with labview 2013?
Thanks and Best regards.
(3,585 Views)
Did you also install NI-VISA?
(3,584 Views)
Hi
Yes, I have intalled NI VISA 14.0.
(3,528 Views)
And did you mistype the version of NI-Serial? The latest is 14.0. There is a 4.1 download but I can't find a 4.0.
(3,523 Views)
Hello qz6y7q,
If you can't find the port on NI MAX I thinks it is a drivers issue, did you installed NI-VISA?
The following link has a LabVIEW/NI-VISA compatibility table:
NI-VISA and LabVIEW Version Compatibility for Windows:
http://digital.ni.com/public.nsf/allkb/CF4279A34F855AB186257B1F00003B82
NI-VISA is a standard for configuring, programming, and troubleshooting instrumentation systems comprising GPIB, PXI, serial (RS232/RS485), USB, and other interfaces. It provides the programming interface between hardware and NI LabVIEW.
You can find a download link on the following link:
NI-VISA 14.0.1:
http://www.ni.com/download/ni-visa-14.0.1/5023/en/
Please check that your SR is on the Operating system compatibility section.
Let me know if this works for you.
Best regards.
David P.
www.ni.com/soporte
(3,485 Views)
