NI-usb 6212 simultaneous analog signal output
Greetings,
I want to generate two independent sine wave from AO 0 and AO 1 by using my NI-USB 6212, but I can not generate it simultaneously. I attached how I tried to generate, but it does not work. Either one of the output is working or the other. How can I generate signal simultaneously?
Thank You.
Message 1 of 13
(3,546 Views)
You should be just using one analog output task for both channels. There is an example in the Example Finder called Gen Mult Volt Updates-Int Clk.vi. Have a look at that and let us know if you still have questions.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 13
(3,544 Views)
Thank you, now I can use both of the outputs,but I have to control them independently.
Message 3 of 13
(3,541 Views)
I mean the amplitude and the frequency of the outputs can be controled independently.
Message 4 of 13
(3,539 Views)
Is it possible to control the amplitude and frequency of the analog outputs independently?
Message 5 of 13
(3,523 Views)
I need a little clarification on your question.  You said you are now able to control the frequency and amplitude independently, but then you asked if it was possible to control them independently.  Did you mean to say dependently in one of these cases?
Chris L
Certified LabVIEW Associate Developer
Message 6 of 13
(3,502 Views)
I can not control the amplitude and the frequency independently, I need help to control them independently. Now they are working in same amplitude and frequency. But my aim is to control independently. I hope I am clear now.
Message 7 of 13
(3,495 Views)
Message 8 of 13
(3,495 Views)
I found this community example at ni.com/code.  I believe it gives the functionality you are looking for.  Take a look and let me know if you have any further questions.
Chris L
Message 9 of 13
(3,489 Views)
I can not open the attachement which you sent. My version is 8.5 how can I open it.
Message 10 of 13
(3,486 Views)
