NI-xNET CAN interface Queued/Single Point/Stream
Hi guys, I want to write a known frame on the Bus 1 time an directly after want to read a frame with a known Identifier. But only that frame, so no other received frames in that time.
What is the best way or only way?
(3,132 Views)
You should post your question to this board.
(3,098 Views)
