NI4351
TBX-68T and pci-4351"
"i Use pci-4351 and tbx-68t to measure the boiled water's temperature through T-type thermocouple.I tied the thermocouple on the channel8's "+"&"-"terminal.Then i use MAX,open the 4351's testpanel,but i get a wrong reading(see the attachment picture).i Use the CJC function of tbx-68t. what should i do??Thanks!!" ANYthing is special to tbx-68t's using??
(2,883 Views)
Check out this other response:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000AE7B0000&UCATEGORY_0=_202_&UCATEGORY_S=0
Jack Arnold
Application Engineer
(2,883 Views)
