NI6034E stream-to-disk rate in Linux
Hi everyone:
We are thinking of using Labview under Linux (RHv7.2) and use the NI603XE cards for data acquisition. What kind of driver support is available? Can the drivers stream data to disk at the rate 200 kS/s as mentioned in the catalog? Any other issues to be aware of?
Thanks in advance
kushal
(2,518 Views)
There are open source Linux drivers for NI cards developed as part of the Comedi project. There is also a beta Edaq driver that supports most E series cards but is not yet supported by NI. Check out:
http://www.ni.com/linux/daq_comedi.htm
(2,518 Views)
