NI6251 buffered digital output/clock
Actually I'm having few issues with the attempt to generate a SPI similar pattern. So I need to generate a clock with the proper pin(using a pin of port0). For some reason I'm having trouble select and to use the right external Source to generate the clock. Do you have any Suggestions to solve the problem? Docs, example Smiley Happy
Thanks.
(3,344 Views)
Hi aethon,
where are you trying to selesct the external source from the clock? Are you using LabVIEW? Can you post a screenshot of your code just to see what is going on?
Corrado
(3,262 Views)
If you want to generate a clock with a digital output pin I think that you can find the example that you need in:
Help --> Find Example --> Hardware Input Output --> DAQmx --> Digital Output --> Digital - Continuous Output.vi
(3,237 Views)
