NI6361
Hi, I am using NI6361. I am transmitting 60 kHz signal with finite samples through AO. And receiving it through AI. My problem is i would like to repeat it frequently like: i should send 60 kHz of one period and receive it at the same time. Then again after 5 seconds, it should repeat the same. Can anyone help me in that case? Thank you in advance.
(3,508 Views)
Hello Rajchk,
I would consider using a State Machine in LabVIEW. You can have one state that checks if the 5 seconds have passed, and another one to generate and acquire.
You can use the State Machine Template that comes with LabVIEW as a starting point.
All the best,
(3,478 Views)
