NI9213 undetected on NI9144 chassis
Hello, I use a compactRIO9074 with three NI9144 châssis. On one of these châssis I use three NI9213 thermocouples modules. Two of these work fine but the one plugged on slot 6 does not work. In the project I tried to add new target, and slot 6 was described as following : "65535 (slot 6) This C-series module is not supported by the current version of NI-industrial Communications for ethercat. "
I do not use FPGA and the two other thermocouples modules work just fine. I replace the module with a new one but nothing changed. Anybody has an idea ?
Message 1 of 1
(1,051 Views)
