12-21-2015 05:54 PM
I am trying to take thermistor emsurements using the NI9219 in the Automation explorer. As a first step, I am trying measure 1 120 Ohm and a 30 Ohm resistor.
Device: NI9219 ( with USB-9162 USB carrier)
wiring: Pin 3 and 5
As an ouput, I am not getting the resistance value
Settings:
Channel 2" 120 Ohm resistor
Max input range: 200 Ohm
Min input range: 10 Ohms
Internal current source set to 500 uA
channel 3: 30 Ohm resistor
Max input range: 40 Ohm
Min input range: 5 Ohms
Result: I am getiing a signal reading which is not in Ohms.
I am not doing something not correctly. Any ideas where my error is ?
Thanks.
12-21-2015 09:41 PM
12-21-2015
10:52 PM
- last edited on
07-12-2026
06:03 PM
by
Content Cleaner
Mike, Actually it looks like he has it wired up the way the manual says to for a 2-wire resistance connection.
http://www.ni.com/pdf/manuals/374473e.pdf page 18
