NI9514 Softmotion Function Blocks/Express VI
I'm using a NI9514 module in hybrid mode with some other modules in FPGA-Mode.
I followed this guide to get a straight line move: http://www.ni.com/pdf/manuals/372874d.pdf
I am not used to working with Function Blocks so i'd like to use the Express VIs, but i coulnd get the axis to move.
I used a stacked sequence to first power and enable the axis and then another sequence to move to an absolut position and the power off again. But the axis does not move at all.
Can anyone give me some hints on how to use the SoftMotion-ExpressVIs? I found this help article, but it does not help me at all.
Greetings!
(3,107 Views)
Hello GerfriedB,
this could help
NI 9514 FPGA and SoftMotion
best regards
Alexander
(3,054 Views)
