NI9514 in FPGA mode
Hi guys,
I recently read about a thread saying that NI9514 module can be used in FPGA mode(https://forums.ni.com/t5/LabVIEW/NI-9514-FPGA-and-SoftMotion/td-p/2173030). But it seems that I can't drag the module below to FPGA Target. And when searching in the example library for some NI9514 examples there's no result. So does anyone has an idea how this should be done? Any reply is appreciated!
Best Regards
(2,639 Views)
Accepted by topic author ZeSuli
FPGA support for the 951x modules was removed in CompactRIO 17.6 and later.
http://download.ni.com/support/softlib//reconfigurable_io/NI%20CompactRIO/NI%20CompactRIO%2017.6/rea...
You can still use SoftMotion 2017 and CompactRIO 17.0 and earlier with 951x modules in FPGA mode, but later versions will be incompatible.
(2,635 Views)
Thanks you for the reply. It's exactly what I want to know.
(2,607 Views)
