NI9870 with cRio9024 interfacing
Dear NI engineer,
my problem is that i am totally new to FPGA as well as LABview I started my work last week I have labview 2010 in this 2010 there is a link getting started with labview when i click it it opens apdf that is very good from that pdf i made 2 -3 examples they are very good explained like what is the control how to configure it etc, but for FPGA part there is no help no tutorial , I have successfully interfaced NI N205 with labview cRio 9024 TR module scan interface
Now as you know NI 9870 does not support scan interface how do i interface it using FPGA interface , we also have can module but the problem is there is no proper support in fpga part ., I am in IIT delhi its academic institute I am doing some research in with the help of compact rio but without using FPGA interface i am not able to use my 9870 module ,
The example which are given in ni website like 9870 serial read write, ondemand write does not expain how they are created, how the FPGA open reference chosen, how the invoke method is configured, means it must be in the format like as you have given that pdf labview getting started ,
can you please share a simple example just to interface 9870 with my hyperterminal using compact rio 9024 chassis 9114 and ni 9870
other wise these product are useless for me
rupesh
(2,592 Views)
(2,498 Views)
Support for the 9870 in scan mode was recently added.  See ftp://ftp.ni.com/pub/devzone/tut/crio_software_versions.htm#crio_rsi for more details.
(2,493 Views)
