NIAuth
Hi!
I have a PC connected through a RMC 8354 (RT) , On my PC i instyalled all driver from february 2012. When i try to deploy the drivers on the target i get the following message :
Cannot continue because of the following unresolved dependancies:
- Ni Web based Configuration and Monitoring 11.5.0 requires NiAuth Web service
- Ni System Configuration Remote support 5.1.0 requires NIAuth 2.0.0
So it seems i haven't all drivers installed on my PC. I searched on the NI site and it's impossible to find a driver called NIAuth. Where can i find this driver ?
(2,948 Views)
Well
I found severeal folder called Ni Auth ... on the device driver DVD... I installed two of them manually, and now it seems to work.
But how can i install NiAuth using the installer, i think this should be installed automatically when we select an option, but wich one ?
(2,941 Views)
