NIMODBUS: Where can i connect the CRC code?
Thanks for your help.
How can I change the stop bit in NIMODBUS?
Message 11 of 13
(823 Views)
It is set inside the MB Serial Init (double click it to see how), so my suggestion would be to place a property node after the init VI, wire the VISA resource into it and change the property to 1.0.
You could also change it inside the init VI itself, but if you do that, you should save that file under a different name.
___________________
Try to take over the world!
Message 12 of 13
(814 Views)
Thank you very much,
I change the stop bit from 1.0 to 2.0. The return data is OK!
thanks again!
Message 13 of 13
(805 Views)
