NIModbuss.dll Cannot Write to Register
I am trying to communicate to a power control board using the NIModbus.dll downloaded from the NI website. I am using the RS232 com port on my PC. The com port is connected to a NOXA RS232 to RS485 converter (2-wire) and then to my power control board. The power control board uses Modbus protocol.
I can read from all of the required registers using Read Input Registers or Read Holding Registers command. My problem is that using Write Single Register and Write Multiple Registers causes a timeout error 6101.
Example:
Function Code: Read Input Registers
Starting Address: 475
Quantity: 1
Returns: 1581
This is correct. We have verified this with other software here.
Function Code: Write Single Register
Quantity: 1
Returns: Timeout Error
Any suggestions?
(3,235 Views)
Are you sure you can write to this input register or is it read only?
Per the Modbus spec.  http://www.modbus.org/docs/Modbus_Application_Protocol_V1_1b.pdf (see page 19), you can write to holding registers (40,000 series), but you can only read from input registers (30,000 series)
(3,223 Views)
Thanks for the reply.
Yes, the register address is 40475 actually.
We have connected a different computer (laptop)  to the NOXA device with RS232 COM port. That laptop has a custom VB program communicating with Modbus. The custom VB program can change the register value.
(3,206 Views)
Try register 474.
The registers in the modbus libraries are 0 based although the device would start them at 1.
(3,204 Views)
I cannot write to many of the registers in the 40000 series. I have tried many including 474, 476. All write commands end up in a time out fault.
(3,202 Views)
You said you were using NIModbus.dll you downloaded.  Where is that?  Do you mean .llb?
(3,195 Views)
Sorry, yes llb not dll
(3,192 Views)
