NISINK not included in the model library
I'm trying to use SIT , after I installed the modules I tried to get the NISINK but I couldn't find it in the library.
the second concern is : can i use SIT with Quanser DAQs?
regards.
(2,884 Views)
Have you recently upgraded the version of Simulation Interface Toolkit that you are using?  If you are used to using an earlier version than 2.0 I can understand why you would be used to seeing these functions but as part of the upgrade in 2.0 they have been replaced.  Check out this knowledgebase article that discusses why this happened.
Simulation Interface Toolkit 2.0 Has Different Function Blocks
As far as using a 3rd party device goes, we don't gurentee support.  You might want to contact the manufacturer of your DAQ board to learn what it is compatible with.  I hope this helps,
Regards
Eric A.
Distributed I/O Product Support Engineer
(2,854 Views)
