NISSLEAY32.dll error
Just wondering if anyone has ever seen this error.
(3,315 Views)
Accepted by topic author mrbean
This dll is for LabVIEW web services. Are you using web services on a remote machine? It is possible if you built an installer that the files were not copied correctly.
  1. From labview\resource\webserver\modules\ copy the following files:
    • libopenSslModule.dll
    • libsslInitModule.dll
    • libsslModule.dll
    And paste them into the following directory on the target computer:C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\2009\webserver\modules\
  2. From C:\Program Files\National Instruments\Shared\nissl\ copy the following files:
    • NIlibeay32.dll
    • NIssleay32.dll
    • nisslinit.dll
    and paste them into the same directory on the target computer: C:\Program Files\National Instruments\Shared\nissl\
  3. Ensure that the certificate and key files located in the directory specified in the niwebserver.conf file.
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(3,299 Views)
