NISwitch
I am using  Labview 2010 (10.0 32 bits) and TestsTand 4.2.1 with a PXI 1033 chssis. In the chassis, there are a PXI-6733, a PXI-7852R, a PXI-2564 and a PXI-2569.
The PC sometimes freezes with a "blue error screen" (look at the attached file).
The file niswdk.dll is in the NI SWITCH files, it is located at C:\Windows\System32\drivers. The version of the dll file is 2.0.1.49152. NI Switch version is 4 .0 .2
I had uninstall the NI Switch software and then I install again the NI Switch sofware but the problems still occurs.
(3,308 Views)
Hi Romain,
When you said "the PC sometimes freezes with a blue screen error", could you give more details about it?
I mean, are you executing specific LabVIEW code or are you doing others tasks before the blue screen occured?
This blue screen is quite strange, so it's important to know what make it happened.
Celine
National Instruments France
(3,270 Views)
Thank you for your answer Celine.
Unfortunatelty, I can't give you more details. The program  is often runned. Most of the time, there are no bugs.
(3,265 Views)
This is difficult to help you if you cannot give more details...
What is your application with your PXI system?
Celine
(3,262 Views)
