NIVISA USB issues
hello i did what u said donloaded daqmxbase310 back to windows update firmware test driver wizard in windows with success (i can select USB), back to mandriva install daqmxbase310 (uninstall base210 first), driver wizard and guess what same again i cant select USB, i dont get it, i can see the device in Visa configuration, but cant select it in driver wizard Smiley Sad
Message 11 of 13
(892 Views)
At this point the only thing I can advise is to call the technical support. This way it will be a better way for us to help you.
You are experiencing strange behaviour.
I hope you'll find a solution soon, or maybe someone of this forum had the same problem...
Regards
Richard Keromen
Message 12 of 13
(887 Views)
thanks for your support Richard i'll try other solutions...
Message 13 of 13
(877 Views)
