NImDNSResponder and NILXIDiscovery cause issues with VPN & system
The two windows processes nimDNSResponder.exe and niLxiDiscovery.exe are installed after installing LabView 8.6.  They run automatically in the background, but have negative effects on system performance.  DNSResponder corrupts the routing table, thus rendering Juniper VPN inoperative.  If that process is stopped niLxiDiscovery begins to consume computing resources (>80% of processor time).  If both processes are stopped, the PC & VPN seem to run normally.  I uninstalled and reinstalled LV 8.6, and have the same results - apparently it wasn't a corruption at install.  Can you direct me to the parts of LV that I must un-install to eliminate the issues associated with these processes?
Thank you,
...jerry
(11,612 Views)
Related Post
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
(11,579 Views)
