04-16-2008 05:16 AM
04-17-2008 05:05 AM
04-21-2008 04:05 AM
04-21-2008 10:21 AM
04-21-2008 11:43 AM
06-24-2008 04:33 PM
11-04-2008 03:46 AM
Same here, ESET NOD 32 ver 3.0 gives the problem, turning it off completely solves it. I'll come back if we find out how to change settings in Nod 32.
11-06-2008 01:15 AM
The problems comes from the "web access protection" part of NOD32, turning that part off solves the problem. As an alternative you can add the web pages you need to access in "web access protection/HTTP/Excluded", I found that only an ip adress is not enough, instead use wildcard like "1.2.3.4*" or the full path "server.mycomp.se/my_labview_app.html".
Ola
10-13-2010 07:16 AM
Hello!
Having the same problem with Kaspersky Internet Security 2011.
Disabling web-antivirus module (not firewall module!) is a solution.
So, it just needs to be configured correctly. Unfortunatly I've failed to find out what web-antivirus module option exactly shoud be configured...
07-25-2011 04:54 PM
I had that problem, and the solution was to change the HTTP port from 80 to 8000, and thats it, then you just need to add the :8000 after the ip like 192.168.1.1:8000/index.html
