NUSS Pressure Scanner from National Instruments
I am using a NUSS pressure Scanner from National Instruments. I have 16 channels to measure the pressure. On the default Labview program, I want to make slight changes to satisfy 2 conditions :
1. I have to transfer the data that is being displayed to a file.
2. I want to select only 9 pressure channels, not all 16, since it slows down the process.
Please let me know if anyone knows how to do it.
Regards
Himanshu
(4,507 Views)
I am sending the actual program. Its the First one in the list with name c command.
If someone knows a way to resolve the problem, I would be really thankful.
Himanshu
(4,497 Views)
Hey,
First of all, this hardware is NOT from National Instruments, it's from Esterline, like the Instrument Driver VIs you are using.
The instrument driver is not very well documented, so I would suggest that you contact Esterline directly for support on this.
Christian
(4,465 Views)
give me detail about of pressure sensor .
today i see the your sub vi.
i will try.i have alredy worked in pressure sensor (esp +/-10"wc) for crri
my cont.no 09911689551/acssml@gmail.com
(4,438 Views)
