02-02-2018 09:00 AM
I decided to install NXG 2.0 on a Win 10 x64 machine. I got the following error message:
I clicked "Try Again" and it worked, so all is good.
However, I'd like to bring attention to the odd logic in the message: How does "File is being used by another process" lead to "Please check your Internet connection"?
Anyway, the next screen had this:
I'm unable to find any mention of "NI Monarch Conversion Support" on ni.com. What is it?
Solved! Go to Solution.
02-03-2018 08:01 PM
I believe that's what helps convert code from LabVIEW to LabVIEW NXG.
02-05-2018
02:08 PM
- last edited on
11-10-2025
09:30 AM
by
Content Cleaner
Hey JKSH,
The Monarch Conversion Support is for the conversion utility to convert LabVIEW to LabVIEW NXG. It supports LabVIEW 2009 and later. Take a look at Converting LabVIEW Code for Use with LabVIEW NXG for further instructions on using this utility.
Best,
Danielle
Applications Engineer | NI
02-06-2018
05:52 PM
- last edited on
11-10-2025
09:30 AM
by
Content Cleaner
Hi Danielle,
It is...?
I installed NXG 2.0, but didn't install any of the "NI Monarch Conversion Support for LabVIEW" packages. I still have the "Code Conversion Utility for LabVIEW NXG 2.0", and I was able to convert a LabVIEW 2017 project.
What extra functionality will I gain if I install "NI Monarch Conversion Support for LabVIEW" now?
02-07-2018 04:27 PM
Hmm that is interesting.. From my research it doesn't look like it adds much functionality for a user, but I am skeptical. I will try looking into it a bit further to see what I can find.
Are you able to convert other versions of LabVIEW?
02-09-2018 09:21 AM
Thanks for investigating.
Interesting; a simple project (1 .lvproj that only contains 1 VI and nothing else) from LabVIEW 2013 SP1 can't be converted. The code conversion tool doesn't say what the error is:
02-12-2018 01:24 PM
Can you provide more details about the contents of the VI you're trying to convert? There are some features in LabVIEW that have not been implemented in LabVIEW NXG yet. I'm wondering if perhaps that could be the cause of the issue here.
02-12-2018 07:16 PM
Hi James,
Thanks for responding.
I doubt it's caused by an unsupported LabVIEW feature, because:
To recap, this is my system:
02-15-2018 12:14 PM
So as it turns out, 2013 SP1 erroring out is no surprise. Converting to NXG is only supported from the current year of LabVIEW and the previous three years (2017, 2016, 2015, 2014). LabVIEW 2013 SP1 has not been tested to convert correctly. If you need to convert an older version to LabVIEW NXG, you will need to convert the 2013 project to 2014 (or another supported year).
It seems like even though you intentionally checked to not install the Monarch Conversion Utility, it was somehow installed anyways. Can you look in NI Package Manager to see if it shows up there?
Best,
Danielle
02-17-2018 07:54 AM
Ah, so that's it. You're right -- re-saving the project in LabVIEW 2014 worked.
I also just discovered: In order to see the detailed error message, I need my mouse cursor to hover and wait over the problem file. Clicking on the filename actually prevents the error message from appearing, unless I move my cursor away and hover again.
According to NIPM, NI Monarch Conversion Support is definitely not installed.
Here are all the packages that are available for installation (i.e. they haven't been installed:
Just to be sure, here is the list of everything that is installed:
