NXG GET HTTP from LabView Web Service
Hi all.
NXG Newbie
Having trouble interpreting this response from HTTP GET
<Response><Terminal><Name>FirstName</Name><Value>Keith</Value></Terminal></Response>
Obviously, I am looking to use an indicator named FIrstName to display Keith
What is the magic incantation?
What am I missing?
Keith
(2,754 Views)
Accepted by topic author DeOdderKeith
Hi Keith,
The response looks to be formatted as XML which NXG does not have built-in support for handling yet. If you need to parse the response as XML there may be exisiting XML libraries that can be migrated to NXG, etc.
Looking at the format it does seem like the response is coming from a LabVIEW Web Service. If you have control of the LabVIEW Web Service you can change the response format to JSON:
Then for the following example Web Method:
You get the following response:
Which can be parsed in LabVIEW NXG using the Unflatten from JSON VI:
Milan
(2,709 Views)
Thanks VERY much !!
(2,678 Views)
