NXG WEB Module Graph Time Stamp error
Hello! I'm trying to display a graph that consists of two arrays - time and data. The time is in Unixtime format. But there is a problem: time is not correctly converted on the X axis. In normal NXG2018-05-17_14-17-55.png2018-05-17_14-18-45.png ev2018-05-17_14-18-45.pngerything is fine and the time functions are converted correctly ... need help !!!
(3,812 Views)
I encountered the same problem while working with Timestamps in WebVIs.
The workaround for you will be to do it like this:
Notice the value you have to add to your Time values!
(3,799 Views)
Thank you, solved!!!
(3,738 Views)
Just in case, someone will see this thread:
While i was porting an application from NXG 2.1 to 3.0, I figured that this bug has been fixed. If you are doing the shown workaround in NXG 3.0, your Graph won't show any values at all!
So in NXG 3.0 this workaround is no longer needed.
(3,527 Views)
