NXG cannot get online help. NGX crushes by login.
first I just tried to get online help in NXG 1.0. It tried to connect, but could not pass through our proxy. I canceled it several times. Now there is no reaction at all, if I click online help.
Then I tried to login (upper right corner of the window). The NXG crushes instantly.
I've sent a crash report either. Protocol-ID:ed34aad2-bd2c-4d3b-b00a-a4674b32ce18
The first idea is of course to uninstall and install again. But how could I then setup the proxy, so it doesn't happen again?
(3,141 Views)
I cannot provide a solution, but is there any reason why you need to use NXG 1.0? You can already download and install 2.0, and it might fix your actual problem too...
(3,129 Views)
Thanks for reply, but NXG 2.0 is beta:
(3,057 Views)
I think the NXG 2.0 is a final release. The recent beta (tech preview) version is 2.1: http://www.ni.com/en-gb/shop/labview/compare-labview-nxg-and-labview.html
But if you want to be sure, give a call to your local NI office...
(3,054 Views)
If it's final release, I'll try it. Thanks!
(3,051 Views)
actually the problem was not solved. I've tried to install 2.0, 2.1 (crashes). Now NXG 1.0 does not crash, but just does nothing. Ctrl-H works, but "More Help" doesn't do anything. Our IT checked if it's our Firewall, but they cannot see any blocked actions.
(2,747 Views)
