NXG front panel center display when running
1、I want to center the front panel when the program is running, where should I configure it ?
2、Is the transparency setting cancelled when NXG front panel is running? There is no such item in the attribute node
(1,972 Views)
1、Is the transparency setting cancelled when NXG front panel is running? There is no such item in the attribute node
2、I want to center the front panel when the program is running, where should I configure it ?
(1,967 Views)
