NXP TED KIT2
Hello
Transponder Evaluation and Development Kit, 2nd Generation: TED-Kit2
Does anyone have experience in intergrating this kit from NXP with LabVIEW.
http://www.mouser.com/catalog/specsheets/OM6716,599.pdf
The sales document mentions "easy" intergration.
Could someone please offer some advice as I want to figure the intergration out first before purchasing the units.
Kamilan
Message 1 of 12
(13,357 Views)
I just started using that device today and can't find the LabVIEW drivers, also got the tk2.dll error. we have some of them here for sure.
For me it is quite interesting but if you are looking for a long range with LF 125KHz link, I don't think it is the solution, I think one of the solution is the Atmel IC base station, go online @ http://www.atmel.com/tools/LFRFIDAPPLICATIONKITATA2270-EK1.aspx
that is for long range applications, hope that help you a little bit.
Try Atmel IC first the cheapest
Cool!
Juan Mejia
315.730.6012
mejemco@gmail.com
Message 2 of 12
(13,352 Views)
Hi Mejemco,
I found the right driver.
Its the header file thats the problem. Any luck with the TED KIT?
Message 3 of 12
(13,317 Views)
Did you ever get this to work?
Message 4 of 12
(11,584 Views)
I tried searching around to find the product or driver on the NXP website and was unable to do so. Since this post is so old you might get more traction by creating a new post with specific questions about the product and integration with LabVIEW. I would also suggest trying to get in contact with NXP to see if they are still supporting this product and would know where to find their drivers for LabVIEW.
Also, if you are looking at doing transponder tests you may want to get in contact with an NI sales engineer to see if there is an NI solution that might work for you.
You can call: (888) 280-7645
http://www.ni.com/contact-us/
Matt G.
Product Manager
Message 5 of 12
(11,566 Views)
Recently till ( April 2016 ) I have been developing new Ted kit v3 ( Was only responsible person).  But I had to leave the country and I guess project is still with Bangalore development team. Project was 75% completed with new colorful UI and as RCP SDK Application.
Milan
Message 6 of 12
(11,160 Views)
支持 HITAG2、HITAG3、HITAGAES、HITAGPRO 系列芯片
运行环境要求:1,LABVIEW2007 或更高版本。
                            2,NXP OM6716 读写器 1 个或更多个(安装好驱动)。
                            3,授权电脑和允许的芯片
一、TED KET2 LABVIEW 驱动 VI 在未授权的客户电脑上运行时会提示需要授权信息,同时会自动在 D 盘根目录生成 NXP LICENSE.license 文件,请将该文件发送给授权人。授权后客 户会得到该电脑的授权文件,将原来的覆盖掉即可永久使用。
二、所有 vi 按芯片型号发布,购买者需提供详细芯片型号(必须含后缀字母)和实物样件至少 2PCS。
Message 7 of 12
(10,372 Views)
雄飞    can you please email me to ask you a question thanks .
Keytechint@gmail.com
Message 8 of 12
(9,769 Views)
 hi,smartkey
My e-mail address is wxf-5555@163.com
Message 9 of 12
(9,751 Views)
wxf-5555@163.com
Message 10 of 12
(9,745 Views)
