NXT bug with an array of non 32bit integers in a cluster
There is a bug in the NXT toolkit.
attached is an llb "non 32bit bug.vi" displays the problem.
If you create a constant which is an array of clusters with no 32 bit data the toolkit magles the creation of the constant. The first element in the array will be correct but the rest of it will be 0xFF for every byte.
Note that the problem does not happen if the array is created dynamically.
The VI runs corectly under windows but not when compiled for the NXT.
Amaury
(2,448 Views)
Hi Amaury,
Thank you for the information.  I have let R&D know, and they are looking into the issue.
If you have future questions regarding the LabVIEW Toolkit for LEGO® MINDSTORMS® NXT, the technical support forum is the LabVIEW Fans of LEGO board.
Thanks again for the feedback.
Jennifer R.
(2,421 Views)
