NaN as Output Data points
Dear friends,
i have written a resistivty program using ke224 current source, ke2182a nano voltmeter and lakeshore325 temperature controller,
the program is running fine, data points are being written to spreadsheet,
but the data point on x-axis is 0000 and on y axis is NaN,
also i am getting an error6 at LSC325,
can you friends please figure out wher i am stucked?
thnaks in adavance Smiley Happy
Message 1 of 10
(5,204 Views)
Hi xy,
so you wrote a VI which you don't want to show.
You used some devices, but don't tell us which kind of connection you use.
You used some functions to communicate, but don't tell us where you got them from and how they work.
You got an error, but don't tell us which function/VI it throws and what you have done to debug that...
But yes, we will be able to figure that out for you! (smiling ironically)
Message 2 of 10
(5,197 Views)
And yet she describes the program as running "fine". Smiley Very Happy
Message 3 of 10
(5,182 Views)
Here is the VI that she posted on a different thread
Message 4 of 10
(5,168 Views)
Hi xy,
why are there FOR loops set to run just once? Why do you use a FOR loop at all?
Where does the error occur? Which function gives that error?
Message 5 of 10
(5,154 Views)
i amnew to this foruma and LabView,
here is the file, just forgot tp attach it in the first post
Message 6 of 10
(5,140 Views)
i am new to this forum and LabView,
here is the vi and output data poinmts file,
just forgot to attach in the first post
Message 7 of 10
(5,138 Views)
fine means, i am not getting any eror
Message 8 of 10
(5,111 Views)
But you said you were getting an error 6. Does this last statement mean that you are no longer getting that?
Message 9 of 10
(5,107 Views)
My first suggestion would to break down the task into chunks  and turn these chunks into subVIs.  Try to make these tasks reusable if possible (ei used in multiple places).  As it stands, I can't figure out what is happening in your VI.
Message 10 of 10
(5,046 Views)
