NaN bug : If A=NaN, and B=NaN, then A==B right? Not according to LV.
I'm trying to write some code that finds NaN's in a 1D array of doubles, but for some reason, the "equals" and "not equals" checks are not working properly.  I'm using LabVIEW 2009, but this bug might be present in earlier versions.
See the attached screenshot and code.
When will this get fixed?  How else can I filter out NaN's from a 1D array?  Is there a "NaN" constant that I can use instead of just typing the text "NaN" into a constant of type double?
(4,163 Views)
This makes sense. NaN could mean any number of things.
PaulG.
Retired
(4,154 Views)
Accepted by topic author RichardBallantyne
This is not a bug. Any comparison involving NaN results in a FALSE for good reason.
To check for NaN, use this primitive.
(4,152 Views)
Thanks for the solution!
(4,143 Views)
