Naive Algorithm for Pattern Searching
Is anyone doing this in LabVIEW?
https://www.geeksforgeeks.org/naive-algorithm-for-pattern-searching/
just curious.
Message 1 of 11
(3,276 Views)
Accepted by topic author _Phobos
Use the "Match Pattern" primitive.
Message 2 of 11
(3,249 Views)
Just another possibility....
Message 3 of 11
(3,235 Views)
i overlooked (n-m) +1 ... 🙈
Message 4 of 11
(3,218 Views)
That works! Thank you!
Message 5 of 11
(3,175 Views)
I have a couple questions. If LabVIEW is zero indexed, I understand why the last search result is 12. What about 9, the second search result? Shouldn’t the output be 0,8,12 if LabVIEW is zero indexed?
The original GeeksForGeeks example output is: 0,9,13.
Message 6 of 11
(3,123 Views)
Maybe there’s a typo in the generated output? The original “calculated” output is 0,9,12.
Message 7 of 11
(3,120 Views)
Your example is also 0-indexed. With the found indices at 0, 9 and 12. Why do you think the second index should be 8?
Message 8 of 11
(3,062 Views)
Look further down the page. The Output lists 0, 9, 13. This is not consistent with 0, 9, 12. I think there is a typo in the Output.
Message 9 of 11
(3,053 Views)
The 9th element in a zero-indexed sequence would be 8. The 13th element in a zero-indexed sequence would be 12.
Message 10 of 11
(3,049 Views)
